1996 lurching forward with brake on
150,000 MILES • 6 CYL • 2WD • AUTOMATIC
HIGHLANDHEART1961
this problem started a few months ago. First it happened when i put the car in reverse, while my foot is still on the brake, it would jerk and seemed to be revving up the motor and trying to move in reverse with my foot on the brake. Now it is doing it when I change gears into drive with my foot on the brake it seems to try and lurch forward in fast speed while my foot is still on the brake. I keep my foot on the break while this is happening because it seems the car is in full throttle and would just jerk forward at high speed if I let off the brake. After a while it will jerk back into a normal throttle or the engine will die and I have to restart it. Sometimes grayish smoke will appear during the high throttle phase. It scares me. It feels like I'm trying to hold back the car from taking off on it's own.
Aug 17, 2008 at 7:51 AM
  • 75,988 POSTS
Sir
You might want to have the idle air control valve and throttle position sensor-
Aug 17, 2008 at 9:58 AM
HIGHLANDHEART1961
This is all your answer said....
Isn't there more to the answer than the above? Does it mean I need to repair these things? Have them looked at and what do they specifically do?
Aug 19, 2008 at 2:50 AM
  • 75,988 POSTS
Okay-Do you have a check engine light and when was the last tune-up?
For a start Have them looked at the IACV-The computer uses the IACV to target the idle speed and maintain that speed. yours is not stabilized. Then report back if further assistance is needed-
Aug 19, 2008 at 6:15 AM
