1995 skylark sputters at idle, and drive...
JOHN1974
  • 11 POSTS
I have a 4cylinder 1995 skylark which started to sputter recently. I thought it was the spark plugs so I replaced those and it still did it. it was only once and awhile and today on my way home from work it starter doing it 100% of the time. It sputters like a plug is bad but we know its not it. I cant get the car over 30mph.
any ideas? no check engine lights are on.
Jul 16, 2007 at 2:30 PM
KREFLO
[quote:796165989c="john1974"]I have a 4cylinder 1995 skylark which started to sputter recently. I thought it was the spark plugs so I replaced those and it still did it. it was only once and awhile and today on my way home from work it starter doing it 100% of the time. It sputters like a plug is bad but we know its not it. I cant get the car over 30mph.
any ideas? no check engine lights are on.[/quote:796165989c]
I am having the same problem with my wifes car, and was wondering if you found out what the problem was? Thanks in advance, Jason.
Sep 7, 2007 at 8:55 AM
RAGMAN
Now I may be wrong but I was told that when a car wont go over a certain MPH then the problem is either a vacuum leak or a map sensor.
Mine was sputtering just like that and there was a small vacuum hose right on the front of the motor that was falling off and cracking. Replaced that, it was like night and day. But now I had the problem again and the hose is fine. I couldnt get it to go over 25mph. I was told it may be the map sensor. Now I just need to find out where the map sensor is on the car-heard its not too difficult to replce, once I find it.
Oct 4, 2007 at 12:21 AM
BERNESTINE
[quote="john1974"]I have a 4cylinder 1995 skylark which started to sputter recently. I thought it was the spark plugs so I replaced those and it still did it. it was only once and awhile and today on my way home from work it starter doing it 100% of the time. It sputters like a plug is bad but we know its not it. I cant get the car over 30mph.
check engine comes on but goes out
Nov 29, 2007 at 8:53 AM
JOHN1974
  • 11 POSTS
Just to let everyone know I solved the problem. It as the white tower that runs to the spark plugs.
Jun 29, 2009 at 6:25 AM
