1995 Buick Skylark 1995 6cyl Skylark rough idle at start
157,000 MILES • 6 CYL • 2WD • AUTOMATIC
JOHN1974
  • 11 POSTS
My parents put in a used motor in this car and it runs pretty good when warm. I bought it from them and it doesnt like to drive when cold even in summer so I have to let it warm up alot. Once warm she runs pretty good but lately it really runs rough at idle when cold and has died a couple of times. Also it sometimes acts like its missing when I drive through the first gear until. I did notice a gas smell at idle when it was running rough. Today it seems fine but for 2 days there it wasnt all good.
I must add those 2 days it was very hot outside and high humidity after a rain. No check engine light on, and I replaced the aircleaner as it was somewhat dirty. Anything I should look for?
Jun 29, 2009 at 6:23 AM
LEGITIMATE007
  • 5,121 POSTS
is there a check engine light on?
Jun 29, 2009 at 6:33 AM
JOHN1974
  • 11 POSTS
[quote:8ac8b8ff76="legitimate007"]is there a check engine light on?[/quote:8ac8b8ff76]
Nope no service lights are on.
Jun 29, 2009 at 6:45 AM
LEGITIMATE007
  • 5,121 POSTS
you could have a weak oxygen sensor, taking extra time for it to go into closed loop operation, but not bad enough to create a check engine light. also , you need to check the engine coolant temp sensor, if that is also weak, it will tell the computer that its cold and the computer will dump extra fuel to try and warm it up, hence the fuel smell.
Jun 29, 2009 at 1:04 PM
JOHN1974
  • 11 POSTS
I took it for a drive and today at idle it ran fine, warmed up it ran pretty good here than there on a 50 mile trip it seemed like it missed on accleration a couple times.
Im thinking spark plugs.
Jun 29, 2009 at 1:59 PM
LEGITIMATE007
  • 5,121 POSTS
well yes, spark plugs are always a good start, could have a couple of fouled plugs, good. but, I still would consider doing a throttle body cleaning. can only help. also the wires could be bad, if you havent done a tune up in a while I would, like you said, consider spark plugs and wires, if it doesn solve the problem you may want to consider what I suggested in the beginning of the post. keep me posted
joe
Jun 29, 2009 at 11:21 PM
JOHN1974
  • 11 POSTS
Ya thats kinda the plan, start at the plugs/wires. Then check the other stuff mentioned. Thanks.
Jun 30, 2009 at 2:33 AM
LEGITIMATE007
  • 5,121 POSTS
keep me posted
Jun 30, 2009 at 6:08 AM
JOHN1974
  • 11 POSTS
Airfilter was kinda dirty so I replaced and plugs and the car hasnt done it since.
Thanks for the tips, and thoughts.
Jul 5, 2009 at 12:15 PM
LEGITIMATE007
  • 5,121 POSTS
awesome , come back anytime
Jul 5, 2009 at 1:07 PM
JOHN1974
  • 11 POSTS
Ok well here is the update. IF we get a good rain or its very humid the car will do this for a couple days only because of this...
thoughts?
Jul 18, 2009 at 2:59 AM
LEGITIMATE007
  • 5,121 POSTS
obviously moisture is getting into something, so i would once again , maticulously , check all of the ignition wiring,/coil pack for cracks or anywhere moisture can be let in.
Jul 18, 2009 at 2:52 PM
