Passenger side turn indicator lights do not work.Have replaced both bulbs.What next?
Nov 18, 2008 at 5:38 AM
JAMES W.
✓Experienced Mechanic
Replace your signal flasher. It could be a cheap flasher. For the flasher to work on one side and not the other is extremly rare, but it does happen. I that doesn't help then I would say it's the switch itself. You could check connections under the dash, but that's usually not the problem. Hope this helps.
