at around 35 m.p.h. the engine stops running but
if you back off on the gas engine runs ?
Jan 30, 2009 at 3:58 AM
JDL
✓Experienced Mechanic
Did you check fuel pressure? Any codes? When was the last time you replaced the fuel filter? If you do change the fuel filter, make sure there is no pressure on the system before you take any connections loose.
Jan 30, 2009 at 4:10 AM
