1993 Buick Skylark Turn Signals
RAYRAY9990
Electrical problem
1993 Buick Skylark 6 cyl Automatic
My turn signals don't work i checked the fuse and its fine is there something else i check or do thanks
Oct 2, 2008 at 2:50 PM
BRANDON56560
  • 13 POSTS
Turn your hazard lights on and check if all lights are working. If a bulb dosn't light up replace it. All bulb need to light or turn signals won't work on side that is burnt out. If all lights are working, try changing out flasher relay. if that dosn't work, have turn turn signal switch check. Thay may call it a multi function switch for that year.
Oct 2, 2008 at 4:04 PM
