THE BREAK HAS TO BE PUSHED ALL THE WAY TO THE GROUND TO SLOW DOWN AND WHEN IT IS FULLY PRESSED IT STILL SLIGHTLY MOVES
Feb 3, 2010 at 6:19 PM
✓Experienced Mechanic
Hi there,
You need to go get the brakes checked asap as you may have a hydraulic leak, check the reservoir and top up if low, you will have to bleed the brakes to get a pedal back, if you can't do this you will have to get it towed as it is far to dangerous to drive on the road with such poor brakes.
