1992 Buick Skylark
1992 BUICK SKYLARK
BALIO
I am looking at buying a 1992 Buick Skylark with 54,000 miles. The problem is it stalls out, usually after it has been running awhile. Some one I know said it is the air intake valve. Does this sound correct. I have tried to search for this part to get a price but have no luck.
I appreciate any insight you can give me!
Thanks
Beth : :?
Oct 4, 2007 at 8:39 AM
BADGE726
  • 9 POSTS
[quote:fec7bcf705="balio"]I am looking at buying a 1992 Buick Skylark with 54,000 miles. The problem is it stalls out, usually after it has been running awhile. Some one I know said it is the air intake valve. Does this sound correct. I have tried to search for this part to get a price but have no luck.
Thanks
Beth : :?[/quote:fec7bcf705]
Try looking for IAC valve(Idle Air Control). I believe it is located on the throttle body. My 94 required a sequence before starting the car after installation. 5 sec with ignition on, 10 sec with ignition off, then start.
It could correct the stalling problem, but there are too many variables to say for sure.
-Steve
Oct 21, 2007 at 1:19 PM
