HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Buick
Skylark
Engine
Symptoms
Runs Rough
1991 Buick Skylark runs rough
TJ5150
MEMBER
1991 BUICK SKYLARK
6 CYL
2WD
AUTOMATIC
135,000 MILES
Car is hard to start and wont accelerate
Sunday, May 16th, 2010 AT 11:42 PM
MECHANIC
Do you have a check engine light and when was the last tune-up?
Check the fuel pressure if its okay-clean out the idle air control valve and EGR valve and test the throttle position and manifold absolute pressure sensors.
Sunday, May 16th, 2010 AT 11:46 PM
Please
login
or
register
to post a reply.
Related Engine Runs Rough Content
Quad Four Running Rough!
Checked Entire Ignition System Everything Working. Engine Starts And Runs Rough Like On 3 Cyl. Check Engine Light Does Not Come On But I...
Asked by
goodwon
1 ANSWER
1991
BUICK SKYLARK
VIDEO
Is it Safe to Drive Check Engine Light?
Instructional repair video
GUIDE
Check Engine Light
Why is my check engine or service engine soon turned on? In this guide we talk about what this is associated with this notorious light, what it is used for and what you...
Engine Over-heating; Runs Rough; Back Fires
1991 Buick Skylark 2.5 Sedan 89,000 Miles. When I Bought It, It Had A Cracked Manifold. I Had That Repaired. It Ran Very Smoothly And...
Asked by
Aleta Sonnenberg
BUICK SKYLARK
1997 Buick Skylark Engine Problems
Check Engine Light Flashes, Engine Runs Rough And Shakes, Dies Frequently
Asked by
izzy2396
1997
BUICK SKYLARK
Repair
1991 Buick Skylark. Starts Then Dies. Have A New Fuel Pump & Coil Pack W/mod Check Ok. How Can I Test Or Find What May Be Wrong?
Asked by
GKC
4 IMAGES
1991
BUICK SKYLARK
1991 Buick Skylark Restarting When Warmed Up
The Car Will Not Restart After Driving For A While On A Hot Day. It Will Start Immediatley After You Shut It Off But Let It Set For 15...
Asked by
hotrod427
1991
BUICK SKYLARK
VIEW MORE
How to Read Codes
Code Read Retrieval/Clear Mercedes Benz
How to Read Codes Chevrolet
