1991 Buick Skylark
RUWWE
1991 Buick Skylark 4 cyl Front Wheel Drive Automatic
What could be wrong with a 91 buick skylark with a 2.5 liter engine that acts like it isn't getting any fuel when accelerating?
Mar 23, 2010 at 11:56 AM
  • 75,988 POSTS
Inspect and test all the following listed below and get back with some testing results we start here
Oxygen sensors.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard.
Mar 23, 2010 at 12:00 PM
