1990 Buick Skylark Power Windows jammed
CHRISEXE
Electrical problem
1990 Buick Skylark Front Wheel Drive Automatic
My passenger door window somehow came off the mechanism that rolls it up/down now it just moves freely my driver door window is having a simarler problem I can still roll it down but no all the way what are the easiest and cheapest fixes
Dec 30, 2009 at 5:41 AM
HMAC300
  • 48,601 POSTS
your pass window needs the rollers repaired . Maybe an adjustment after hooking them up will fi it but i doubt that. the other window is called lube. use silicone spray in the window channels , make sure the window is down and then pul the door panel off and lube the window mechnism.
Jan 31, 2010 at 10:21 AM
