1990 Buick Skylark Oil Leak
84,390 MILES • 4 CYL • FWD • AUTOMATIC
BLUE6399
Hello, i have an oil leak i cant seem to stop. The oil is leaking around the "round" access plug to get to the oil filter. I have taken the plug out twice cleaned it and put back in place no difference. Is there a rubber type seal or something that goes around the plug, mine dosent have one don,t know if it did have or not. When i had the oil changed at a station it didin,t leak, just since i done it it,s leaked. The first time i changed it the plug droped in the oil thought maybe a seal came off when it did. Thanks
Aug 19, 2009 at 12:11 PM
  • 110,246 POSTS
If you are refering to the oil drain plug on the oil pan, yes it should have a gasket.
Sep 29, 2009 at 3:40 AM
