Engine Cooling problem
1990 Buick Skylark Automatic
I have been having problems with the car overheating. I have replaced the thermostat and flushed the system and am still having the overheating problem. The cooling system has a sealed radiator with the pressure cap on the overflow resevoir. While adding anti-freeze to the resevoir earlier, I noticed metal flakes in the water. The water pump appeared to be working but I could be wrong. Could the water pump be the cause of my overheating problem as well as the origin of the metal flakes? Any suggestions would be welcome!
Oct 21, 2009 at 8:36 PM
