1989 Buick Skylark Speedometer
110,261 MILES • 4 CYL • FWD • AUTOMATIC
PAUL HOFF
My speedometer worked fine prior to my replacement of the crank position sensor, ignition control module and coil packs. My speedometer now indicates approximately 1 1/2 the normal speed. Is there a vehicle speed sensor that has failed or have I a bad connection?
Oct 12, 2010 at 2:07 PM
JDL
  • 16,098 POSTS
There is a vss. You may need to remove passenger side front tire. Safely support the vehicle. Are there any applicable trouble codes? The vss is usually in the halfshaft housing.
https://images.2carpros.com/forum/automotive_pictures/170934_buick_skylark_vss_1.jpg
Oct 13, 2010 at 4:27 AM
