1989 Buick Skylark car has to warm up before shifting into
1989 BUICK SKYLARK
ELF1
Transmission problem
1989 Buick Skylark 4 cyl Front Wheel Drive 100000 miles
Car has to warm up before shifting into first gear.I think it might be a tcc solenoid. But I am not sure. If this is the problem is it something I should do myself. Ihave changed the fluid and filter, no change. Please try to help me. Thank you
Jan 14, 2009 at 2:08 AM
BJKREITZ56
have this same problem. Did you ever get an answer to what causes this?
Jan 22, 2009 at 11:28 PM
MR62BUICK
  • 12 POSTS
ok, I can assume the transmissions have never been rebuilt since it is GM. (fords would have gone through 5 units and chrysler 3 by 80K) Anyways, the reason why the unit has to get warm is that the seals are hard and the fluid goes by the seals since they cannot seal up the apply pistons inside the units. There r two ways to fix, one is to rebuilt the unit and have the unit get new o'ring seals, the next is to use "TRANS-X" in the fluid. This is a last ditch effort in getting the seals to seal. It swells and softens the seals, but can also do damage to the seals, so follow the directions to the letter! Good luck!
Feb 27, 2009 at 3:59 PM
