1988 Buick Skylark starts and shuts off
BOSSCHUBBS
  • 1988 BUICK SKYLARK
  • 4 CYL
  • FWD
  • 100,000 MILES
Engine starts fine and injector is spraying fuel. Injector then stops spraying fuel and engine dies. Just as engine dies it sprays fuel again. Ive replaced all sensors/controllers o2, heated air intake, map, throtle position, air idle valve, oil psi switch, water temp, cam position, ignition control module, and the ecm but not the prom. Checked fuel pressure reg it looks good and the injector seems to spray fine. Its seems as if the ecm is turning the injector off due to a rich fuel mix and then when the engine starts to die it turns it back on but not quick enough.
Tuesday, October 5th, 2010 AT 12:50 AM
HMAC300
  • 48,601 POSTS
The injector gets the signal to spray from the distributor. These 2.5L had a reluctor problem in the distributor. They would crack and quit sending a signal as well as making the engine die so check your distributor, you need to take the dist out to check this.
Tuesday, October 19th, 2010 AT 6:41 PM
