1988 Buick Skylark RPM's Drop and car Shakes
38,062 MILES • 6 CYL • FWD • AUTOMATIC
1988BUICKSKL
My Buick's RPM's Drop when going 40mph or higher and the stearing collom shakes really bad, not just when going up hills. what could be the problem?
Jan 20, 2010 at 4:31 PM
  • 110,246 POSTS
If the RPM's drop and you feel a vibration, chances are the problem is the engine is missing. I would start by checking fuel pump pressure.
Here is a how to:
https://www.2carpros.com/how_to/how_to_check_fuel_pressure.htm
Something tells me you are not getting enough fuel. If the pressure is low, check it before the fuel filter to make sure it isn't plugged.
Let me know what you find. Also, I am assuming that the check engine light hasn't come on because you didn't mention it.
ALso, most parts stores will lend or rent the pressure gauge you need.
Jan 21, 2010 at 12:13 PM
