1984 Buick Skylark overheating
93,000 MILES • 6 CYL • FWD • AUTOMATIC
CATTINELLI
Building excessive pressure on coolant system and running hot.No water in oil,no smoking,no water leaks
Aug 27, 2009 at 4:48 AM
HMAC300
  • 48,601 POSTS
If you have no leaks and it overheats, then fill it up with coolant, making sure it's cool when you do this. Drive it until it overheats then shut the car off. then open the hood and with the car off place your hand on several spots on the radiator backside. If you feel any spots that it is cold or not the same temp as the rest of the radiator then you need another one. If there are any loose rows of fins or greenish looking ones you also need another one.
Sep 10, 2009 at 6:03 AM
