1971 Buick Skylark rear main seal
TONY945
Engine Performance problem
1971 Buick Skylark V8 Two Wheel Drive Automatic
how to replace the rear main seal
May 3, 2010 at 12:46 PM
HMAC300
  • 48,601 POSTS
this is what is called a rope seal. you'll have to drop the oil pan, which means jacking the motor up to get it out and having the crankshaft at a certain position to get it out. then you'll need what is commonly called a "chinese bandit tool" your rear main will have to be pulled out as well. You need the tool for the top piece as you can replace the bottom one easily. they wil have to be cut even with the caps and then using a dab of silicone to ensure no leaks......before you put the cap back on and retorque it.
May 12, 2010 at 12:54 PM
