1986 Buick Skyhawk moter will not start i checked fuel and
ALEX11
Engine Mechanical problem
1986 Buick Skyhawk 4 cyl Front Wheel Drive Automatic 130K miles
130,000
Jan 14, 2010 at 6:20 AM
JDL
  • 16,098 POSTS
Welcome to the forum, what was the fuel pressure spec? You have good spark at all the plugs? How long since a tune-up? Are there any trouble codes?
Jan 14, 2010 at 6:44 AM
DSAN1
I'm going to have to retrieve the codes if there are any. I just read how to do that. As far as fuel pressure, there is plenty!
Oct 27, 2014 at 9:17 PM
DSAN1
Also there is good spark at all the plugs. FYI I installed all new plugs, wires, cap, rotor, coil, and battery. I just put on a different cylinder head and have adjusted the valves twice, just making sure they were right. I left the valve cover off so that I could make sure that the spark was at the plug at the right time for combustion. It should run, but nope!
The check engine light is on , but if I'm getting spark and fuel and not running
Oct 27, 2014 at 9:29 PM
