2005 Buick Roadmaster Car won't start, will crank, and smel
180,000 MILES • V8 • 2WD • AUTOMATIC
MIKE0318STI
No leak detected, I can hear the fuel pump running when key is put into "ON" position. Thinking it might be the spark plugs, or the engine is flooded. This is not my car, its my grandparents. They had a lot of stuff done at a Jiffy Lube, so I'm thinking they had a lot of stuff that didn't actually get done. Thanks.
Aug 31, 2008 at 6:13 AM
  • 75,988 POSTS
Could be that there's a problem within the ignition components that's causing it not to produce spark-
Aug 31, 2008 at 6:18 AM
MIKE0318STI
What would be the best way to check the ignition components?
Aug 31, 2008 at 6:29 AM
  • 75,988 POSTS
Start by disconnecting plug wires and grounding it while cranking the engine over-do you have spark?
Aug 31, 2008 at 7:03 AM
