rear clunking?
76,000 MILES • V8 • 2WD • AUTOMATIC
DOUG1313
This is a wagon with positraction. Occasionally at speeds less than 3mph with drivers window open I hear a clunking noise coming from the left rear of the vehicle. I had a 1994 that did the same thing and the rear end needed to be replaced. Have had brakes and rear differential inspected both OK and had differential oil replaced with posi additive. Ideas?
Dec 3, 2008 at 5:23 AM
JAMES W.
  • 2,394 POSTS
A couple questions. Is the "clunk" at wheel speed or faster? Does it clunk on acceleration, deceleration or both? With the vehicle stopped, does it clunk when shifting from drive to reverse and back? Please advise.
Dec 3, 2008 at 11:38 AM
DOUG1313
I would say clunk is at wheel speed. Only hear noise at walking speed or slower. Have heard it when slowing and after releasing the break, as the speed increase clunking stops. No clunking when shifting transmission.
Dec 4, 2008 at 1:02 AM
JAMES W.
  • 2,394 POSTS
When the noise is present, if you "lightly" step on the brake, does the noise cease? Also, when you step on the brake during a normal stop, does the pedal pulsate up and down?
Dec 4, 2008 at 1:43 AM
DOUG1313
Hard to answer your first question because it happens infrequently and I have not paid attention to that and the noise appears at such low speeds that when you step on the brake the car stops and the noise ceases. No there is no brake pedal pulsating in normal stops.
Dec 4, 2008 at 1:49 AM
JAMES W.
  • 2,394 POSTS
Well, the only thing left is the positraction itself. The noise you describe may the clutches in the rear end slipping just a little. This usually occurs when running two different sized tires on the rear. I'm sure your running numerically the same size tires, but the "physical" diameter may different just enough to cause the clutches to jump. You may want to check this. I used to supply tires to a guy with a circle track race car. He ran P235/15 tires on his car and would measure the inflated diameter of each tire. The diametwers would vary as much as 2 1/2" in. on brand new tires. He would run the larger ones on the right side. Let know what you find.
Dec 4, 2008 at 3:53 AM
DOUG1313
thanks for your analysis. Is this something I can ignore at this time given its sporadic nature?
Dec 5, 2008 at 12:37 AM
JAMES W.
  • 2,394 POSTS
I wouldn't consider it serious. GM positraction rearends have made noise for eons. It is considered charactoristic of the design, most commonly caused by the wrong additive or lack of. According to your posting, you have an additive so I wouldn't be too concerned.
Dec 5, 2008 at 1:56 AM
