1996 Buick Roadmaster fuel starvation
143,000 MILES • V8 • 2WD • AUTOMATIC
JOHN SPADAFORE
I have no check engine light on.
I changed filter and pump and wiring pig tail.
when I turn key to on position I get voltage briefly.
When i attempt to start I get voltage then nothing.
will OBDII scanner help solve this problem.
Sep 8, 2008 at 4:43 AM
  • 110,248 POSTS
Hi:
The scanner could help. Before you try that, check the fuel pump relay and make sure it's good.
Nov 17, 2008 at 12:01 AM
