1995 Buick Roadmaster overheating
80,000 MILES • V8 • 2WD • AUTOMATIC
RILEY DRAKE
what are the possible causes for car getting hot?
Oct 13, 2008 at 4:37 PM
MUSTANG87
  • 261 POSTS
bad radiator flow-stuck thermostat-fan motor not running.water level to low. you might also have fan motor with fan clutch also ,both.can be a weak fan clutch too.check fan by turning on your ac with motor on and wait till fan motor starts sometimes it takes a while.if it dont start take it out and check it outside on direct power from battery with wire.also check oil if any sighns of bad head gasket.
Oct 14, 2008 at 2:39 PM
