1995 Buick Roadmaster Oil filter adpater leak
1995 BUICK ROADMASTER
150,147 MILES • V8 • 2WD • AUTOMATIC
EASTSIDEAUTOREPAIR
  • 5 POSTS
The problem is that the oil filter adater is leaking from the oil filter is attached. We charged the oil filter twice and it still leaks. We cleaned and made sure that it was tight.
Dec 3, 2008 at 12:54 AM
DOCFIXIT
  • 18,828 POSTS
Make sure you have been given the right filter and not to over tighten. Does it have an oil cooler adapter? Berove threaded hex the remove adapter clean up torque to 30ft. lbs install filter. Cross fingers
Dec 3, 2008 at 1:09 AM
