1994 Buick Roadmaster water leaks on the floor of the passe
1994 BUICK ROADMASTER
167,110 MILES • V8 • 2WD • AUTOMATIC
JERRY ZINGERMAN
The a/c drain line is open and has been cleared. The cold water drips from the inside. What do I need to do to repair this? Where do I find the parts if needed? Thank you.
Jul 29, 2010 at 1:57 AM
  • 110,244 POSTS
Have you checked for cracks in the plastic under the dash? Also, are you sure the drain is clear?
Aug 22, 2010 at 3:38 PM
