1994 Buick Roadmaster tempature gauge isnt working
146,000 MILES • V8 • 2WD • AUTOMATIC
ROADMONSTER94
replaced tempature sensor on the front of water pump and gauge jumps to hot then back to cold when i start it but still wont come of cold any ideas?
Apr 17, 2010 at 11:41 AM
  • 110,248 POSTS
I think you replaced the wrong temp switch. One if for engine performance, the other sends a signal to the gauge in the car. It should be mounted to the engine block. I believe it is on the driver's side, lower engine area, front of exhaust manifold, mounted in engine block. Also, check under the hood, passenger side, rear engine area, end of valve cover, mounted in passenger side of engine block
Let me know what you find.
Aug 22, 2010 at 3:50 PM
