1994 Buick Roadmaster roadmaster blaster
210,000 MILES • V8 • 2WD • AUTOMATIC
ROADMASTER3000
I have 94 roadmaster, i was told by my mech,that my sensor and coral pak keeps shorting out, he had a diagnostic test done on the computer and the computer is showing afault, iam told that something is shorting the computer and maybe its electrical problem,also my battery will go down if i let the car set for over 10 hrs.
May 7, 2010 at 12:47 PM
  • 31,937 POSTS
Hi there,
Thank you for the donation,
I would start with a current draw test on the electrical system, this is where an Amp meter is placed between the battery pos terminal and the battery cable and with all doors shut and key out, check the current draw, get your mechanic to do this test, if he can't let me know and i will give you a full description of how to do this simple test.
mark (mhpautos)
May 11, 2010 at 4:59 PM
