1994 Buick Roadmaster dont know what to do
101,000 MILES • V8 • 2WD • AUTOMATIC
DANTE703
the car goes into 1st gear smothly the 2nd gear it dont skip engine revs up i let off the gas then the car jerk and goes into gear it needed a new radiater and i put it in then thats when i noticed these problems befor no problems
Dec 28, 2008 at 12:44 PM
  • 31,937 POSTS
HI there,
Is your transmission oil cooler part of the radiator? if so make sure that it has flow as if it is blocked this may be causing your problems, otherwise get a transmission specialist to do a test & report for you as there will be a few tests that can be run to help determine the cause of your problem.
mark (mhpautos)
Dec 28, 2008 at 8:17 PM
