1993 Buick Roadmaster fuel filter
13,330 MILES • V8 • FWD • AUTOMATIC
2HI2FLY
the acceleration is slow and also when at a stop applying break, car turns off, was if fuel needs replacing or should i be thinking otherwise.- Juan
May 22, 2008 at 3:52 AM
FREEMBA
  • 1,152 POSTS
If your car is fixed by now, Happy Driving. If not, a general tune-up should take care of this problem. However, have your technician to pay close attention to the PCV system (check it to make sure its working well). Sometimes it becomes clogged and has to be cleaned out so that vacuum can be felt at the end of the PCV vale when the engine is running. Also have the injectors and throttle body cleaned. Hopefully this will help...if you still need it.
Oct 7, 2008 at 2:43 PM
