No Idler arm on it. RAck and pinion gear with tie rod ends.
When you shook the wheels, did you move your hands around to different clock positions? Sometimes the 3 & 9 (tie rod, steering) or the 6 & 12 ( suspension/ball joint) positions don't always uncover play.
I don't know the history of the tires on yours but, if the fronts are out of balance, fair chance the rears would be also. Rotating may not be the best check on that.
Tuesday, September 4th, 2007 AT 2:31 AM
