1998 Buick Le Sabre Rear Sag and Squeak
FDMEDIC84
I have a 98 Buick Le Sabre with 106,543 miles. I had the back struts replaced about a year ago. After getting them put on i notice my back end seemed low. The car rode and still rides smooth so I never thought of anything, it just looked low in the rear low. Is that ok? My other question is they squeek recently for about 2 months now, very loud everytime I hit a bump, step on my brakes and accelerate. It's embarrasing driving around and sounds like there is something wrong, what is wrong with my struts?
Feb 20, 2007 at 1:11 PM
CHEVY22
  • 1,375 POSTS
springs are what hold the car up and they will wear over time and cause the lowrider effect , as far as the noise it could be the spring isolators which are rubber cups around the top and bottom of the spring or the strut mounting plates will cause noise , get back there and bounce it around with a buddy and try to isolate the noise , if you have the springs replaced all of the things i mentioned can be checked by the shop while its apart
Feb 21, 2007 at 5:16 AM
Suggested Repair
The low rear is likely from worn springs rather than the struts. The squeak may be from spring isolators or strut mounting plates. Bounce the rear with a helper to isolate the noise, and have those parts inspected if the springs are replaced.
Conversation Summary
The owner of a 1998 Buick Le Sabre says the rear looks low after strut replacement about a year ago but still rides smoothly, and it has recently squeaked loudly over bumps, braking, and acceleration. The expert explains that worn springs cause the sag and that the noise may come from spring isolators or strut mounting plates. They recommend bouncing the rear to locate the noise and checking those parts if the springs are replaced.
