the antilock brakelight is on and it has brake fluid what do i check next? also the traction control light is on
May 13, 2006 at 4:25 AM
Have the ABS system scanned with an ABS-capable scanner to identify the failed component. With an ABS fault, traction control is disabled, but the brakes still operate as normal power brakes.
The owner of a 1995 Buick Riviera with 80,000 miles reports the ABS and traction control lights are on despite having brake fluid, and asks what to check next. The expert says an ABS component failure sets the light and disables traction control, so the codes must be read with an ABS scanner; braking returns to normal power assist. Another owner described a similar Grand Prix issue caused by a loose jump-start terminal connection at a fuse panel.
