1998 Buick Riviera Supercharger belt
KVBOXERS
Engine Mechanical problem
1998 Buick Riviera 6 cyl Front Wheel Drive Automatic 198K miles
My daughter is 18 and I bought her a 98 riviera.
Apparently, the supercharger belt is broken. I want to know if it is alright for her to drive it to work (approx 15 miles one way) for a few weeks until I can afford to get it fixed.
I know I have to find out if the pulley is broken before replacing the belt or it will break again. If the pulleys seem fine then I am going to try and replace it myself. I read somewhere that there were only 3 or 4 bolts involved. Is that correct.
I know the car has a LOT of miles on it I am thinking it does not have the original motor for a few reasons one the engine is immaculate and runs as quiet as a new car. Is there any way to find out if the engine has been replaced. Before I bought the car I did a carfax report and it showed the car was a 2 owner car and it is obvious that whoever had the car took immaculate care of it My question is is it possible fo a car to have almost 200k miles on it and still run like new. Mostly just curious about this part and wondering how long the car will last her.
I appreciate your help very much
Thanks a lot,
Kathy
Jul 21, 2009 at 4:48 AM
BUDDYCRAIGG
  • 2,262 POSTS
I'll try to get to the meat of the questions.
CAN THE CAR BE DRIVEN WITH OUT THE BELT.
yes, but the super charger will be a major restriction in the air intake system. The engine will most likely lack power, and since it will not be responding the way the computer is expecting it to, the check engine light will probably come on.
WILL IT HURT THE CAR
probably not, but no one can give you a 100% approval. Cause there are no documented cases of the SC engine being driven for extended periods without the belt in place.
HOW LONG WILL THE CAR LAST
A car can last forever if you want to keep fixing the things that go wrong with it.
No one can say how long before an expensive repair will be required. Even if it was my own personal daily driver, things happen.
My 96 Grand Am with 128,000 miles had a catastrophic failure in the transmission 2 weeks ago, no warning what so ever.
Have you called anyone in your area for an estimate?
It shouldn't be that much.
Jul 21, 2009 at 10:12 AM
KVBOXERS
I took it to a mechanic and he said the belt was 70 and 120 for labor
Is the belt hard to put on?
How can i tell of the pulley is bad?
i think thats all i needed to know
Thanks again
Kathy
Jul 21, 2009 at 10:24 AM
BUDDYCRAIGG
  • 2,262 POSTS
The price he gave sounds acceptable.
is it hard to put on?
I dont think anything is hard to do to a car, it's all relative to your abilities.
Jul 21, 2009 at 11:48 AM
