we change our oil and seems to take 4 and half quarts.do we need supercharge oil to go in that part of the engine and how much?
Sep 15, 2010 at 6:18 AM
HMAC300
✓Experienced Mechanic
just the regular oil you normally use is good. You coudl use synthetic oil if you want in the engine. The SUPERCHAGER IS NOT SERVICEABLE, meaning it is only a replacement if anything goes bad on it. That is about the right amount of oil you are putting in with an oil filter.
