1998 Buick Riviera MISSING,INTAKE BACKFIRES
YAMAHA11
Engine problem
1998 Buick Riviera 6 cyl Front Wheel Drive Automatic 248K miles
Backfires at low rpm load condition sometimes violently. If rpm is increased to the point of a downshift, the engines runs great.The problem is intermitten but always happens during the condition above. Have replaced plugs,wires,coils,and TP sensor. The problem usually occurs after shifting into high gear, but will backfire in lower gears with same condition.
Feb 7, 2008 at 4:14 PM
2CARPRO JACK
  • 11,533 POSTS
Are we talking a backfire, or an engine miss? Might want to have a compression and leakdown test done on the engine. Could be a leaking intake valve. Have you ever replaced the injectors?
Feb 8, 2008 at 11:55 PM
