1997 Buick Riviera Re-sets
185,000 MILES • 6 CYL • FWD • AUTOMATIC
AIR2TGR
I have noticed the radio cutting out and thought it was the reception. Randomly, the car will re-set the radio, clock and trip meter. The inside lights will blink. It's progressively getting worse, the radio cuts in and out and today the car completely died while I was driving it but I was able to re-start it quickly. I have checked the battery and cables for corrosion and nothing is loose. I also checked the fuse boxes and nothing is loose there. Help!!
Dec 13, 2007 at 6:26 AM
2CARPRO JACK
  • 11,533 POSTS
try wiggling the key or the wires under the dash on the column for the ignition switch. May have a loose connection in there.If ok, next time it (radio) isnt working test for power at the fuse panel
Dec 13, 2007 at 10:50 AM
