Hello, you need to check for voltage at the power seat circuit breaker. Should be hot all the time. If the circuit isn't hot, check the power seat fuse for voltage. None of the power seats works?
Aug 24, 2009 at 3:07 AM
LEFTWICH75
MEMBER
were is the fuse located and were is the circuit breakers
Aug 24, 2009 at 3:23 AM
JDL
✓Experienced Mechanic
Hello, your owners manual should give the location of your fuses. Look under the rear seat?
Aug 24, 2009 at 4:20 AM
