1997 Buick Riviera humming noise at 30mph in tires
164,645 MILES • 6 CYL • FWD • AUTOMATIC
MLH4321
When the car hits 30 mph it starts making a humming noise in the front end. There is also uneven wear on the front tires. Particularly on the edges of the tires. The passenger side tire is worse. Also, when the brakes are applied there is some vibration in the tires.
Nov 3, 2009 at 8:28 AM
  • 31,937 POSTS
Hi there,
You have an alignment problem that may entail worn steering or suspension components, the vibration under brakes is usually warping of the brake rotors, have this inspected.
Mark (mhpautos)
Nov 3, 2009 at 9:25 AM
