1996 Buick Riviera slow takeoff
1996 BUICK RIVIERA
160,234 MILES • 6 CYL • 2WD • AUTOMATIC
RIVIERALOVER
Hi , I have a 1996 buick riviera and when I got it started and put it in gear it took off very slow and did not change gears .so I put a used trans in it with very low miles (under 70,000) and it did the same thing as the trans that I took out. it takesoff very slow before it pickup speed and it does not shift gears . can you please help me because I know its not the trans, could it be a sensor or solenoid ?????
Aug 11, 2009 at 8:30 PM
CAR WIZARD
  • 11 POSTS
trans is electronically shifted.you need a scan tool to watch input speed and shift soliniod operation.could be a quad driver in the ecm also.god luck.
Aug 11, 2009 at 8:39 PM
