1996 Buick Riviera QUITS RUNNING
136,000 MILES • 6 CYL • FWD • AUTOMATIC
CHRIS AND CHELLE
quits running after driving for fiew hours does not overheat, let it sit for hour or so and it runs again for a while then dies, could it be camshaft sensor or is it something else and how do we fix it? we had a mechanic look at it but they didnt know put it on computer and cleared a fiew codes it ran for a day from colorado to phoenix then died again. we need to know what it will cost to fix. thank you
Jul 15, 2010 at 3:38 PM
  • 75,988 POSTS
Next time it dies out don't wait for nothing do below immediately to determine if its a fuel or spark problem
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Jul 15, 2010 at 10:55 PM
