1996 Buick Riviera fuel pump, or fuel relay
RMCD98
Engine Mechanical problem
1996 Buick Riviera V8 Automatic
car will only start if you pour gas into the engine. think maybe the fuel pump, but someone said maybe the fuel relay, can you tell me where the fuel pump relay is .
than you
Oct 17, 2008 at 12:16 PM
  • 75,988 POSTS
Do you hear the fuel pump when you put key at On position for 2secs? If not check the fuel pump fuse and fuel pump relay-
You sure this is a V8 engine? I'm coming up with a V6 3.8L engine on this 1996 Buick Riviera
Oct 17, 2008 at 1:02 PM
