1996 Buick Riviera Fans won't come on
1996 BUICK RIVIERA
TONYBOY52
Engine Cooling problem
1996 Buick Riviera 6 cyl Front Wheel Drive Automatic
Have replaced fans and temp sending unit.
May need cool temp unit but can't find it on motor
Need digram and reason why fans won't come on they are all new
May 7, 2010 at 5:30 AM
BLUELIGHTNIN6
  • 16,542 POSTS
check fuses and cooling fan relay(s). if OK check engine coolant temp. sensor located under thermostat housing.
May 7, 2010 at 5:57 AM
TONYBOY52
Replaced sensor then found out that fans don't come on until 220 degrees they now work
Thanks
May 7, 2010 at 9:17 AM
