1995 Buick Riviera Wiper fluid
1995 BUICK RIVIERA
BLC
1995 Buick Riviera 6 cyl Front Wheel Drive Automatic
The wiper fluid is barely coming out of the nozzles. I'm assuming the hose has broken, I can hear the motor on the pump. I thought that I could just change the hose, but I can't seem to find where the hose actually goes after it leaves the holding bottle. Can anyone tell me what to take apart to get to the hose?
Thank You
Jan 11, 2010 at 7:32 AM
HMAC300
  • 48,601 POSTS
before chanig hoses , try takin some thin wire, like package tag wire an drunning that in and out of the sprayer a few times. Alot of times they jut get clogged up and don't work. If you are in a northern clime, then if it is very cold out wait until yor car has warmed sufficiently warmed up and see if the underhood temp will let them work better. IF that is the case then don't mix your wiper fluid with water as it's freezing in the hoses...
Jan 15, 2010 at 12:13 PM
BLC
[quote:9be903ef69="hmac300"]before chanig hoses , try takin some thin wire, like package tag wire an drunning that in and out of the sprayer a few times. Alot of times they jut get clogged up and don't work. If you are in a northern clime, then if it is very cold out wait until yor car has warmed sufficiently warmed up and see if the underhood temp will let them work better. IF that is the case then don't mix your wiper fluid with water as it's freezing in the hoses...[/quote:9be903ef69]
THANK YOU! I'll try that.
Jan 16, 2010 at 1:43 AM
