1995 Buick Riviera Window doesn't work
108,000 MILES • 6 CYL • FWD • AUTOMATIC
MADDOGIE
95 Buick Riviera driver side power windows switch doesn't work but power lock switch works (same part). Installed new switch. Both windows worked from driver side switch. Try an hour later and have the same problem again. Any suggestions?
May 6, 2010 at 2:03 PM
HMAC300
  • 48,601 POSTS
this can be a couple of things. It can be the window motor or the wires ging through the door are almost broken. This happens alot especially from the older cars that the door is opened and closed all the time..... You'll have to check to see if you have any power to the motor. that should tell a lot.
May 12, 2010 at 12:50 PM
