1995 Buick Riviera type of coolant
88,000 MILES • 6 CYL • 2WD • AUTOMATIC
SMYLEEE
I put supertech coolant and am not sure it is the right kind....it says it is for all metal corrosion protection including aluminum..... Will this harm my car? should I flush it? what kind is recommended?
May 30, 2010 at 4:22 AM
  • 75,988 POSTS
Type of coolant: DEX-COOL
Refill the cooling system with a coolant meeting GM Specification 1825-M. To ensure sufficient engine cooling, freezing and corrosion protection, maintain the protection level at -37°C (34°F) or lower. Use a solution that is no more than 70 percent antifreeze. CAUTION: Under some conditions, the ethylene glycol engine coolant is combustible. To help avoid being burned, DO NOT spill antifreeze or coolant on the exhaust system or hot engine parts.
May 30, 2010 at 8:51 AM
XOVANGAM
There is a class-action lawsuit against GM. Apparently the DexCool that came from them when manufactures ate away at some seals. Do a google search on it.
Jun 2, 2010 at 10:04 AM
