Turn signals not flashing.
1995 BUICK RIVIERA
166,000 MILES • 6 CYL • FWD • AUTOMATIC
JAYFLORIDA
My turn signal has stopped working, but at times attempts to work, but "struggles" if you will. My emergency lights work perfectly and all my bulbs are good. I located and replaced the flasher I found under my steering column, but it didn't change anything. I was told that there are separate flashers for the turn signal and emergency flashers. I've located one, but can not find the other. I'm not sure if I replaced the correct flasher. Any advice or recommendations?
Nov 9, 2010 at 4:37 AM
DOCFIXIT
  • 18,828 POSTS
The turn signal flasher is located behind the left hand side of the instrument panel, attached to the left hand sound insulator.
Cheers
Nov 9, 2010 at 4:57 AM
