1995 Buick Riviera horn
DENISE SURDUKOWSKI
Electrical problem
1995 Buick Riviera 6 cyl Front Wheel Drive Automatic
Both horns don't work. I need to register the car soon. I've replaced the 20 amp fuse and it blew. I replaced it with a 30 amp fuse and it did not blow but it didn't fix the problem. What can I do next?
Apr 29, 2008 at 2:51 AM
2CARPRO JACK
  • 11,533 POSTS
Need to put the lower amp fuse back in it so you dont damage anything. Then locate and disconnect the horns to see if it blows the 20 amp fuse, if not replace them. Otherwise could be a short in the column wiring
Apr 29, 2008 at 5:19 AM
BUZZSAW
  • 1,198 POSTS
[quote:597d2c0700="Denise Surdukowski"]Electrical problem
Both horns don't work. I need to register the car soon. I've replaced the 20 amp fuse and it blew. I replaced it with a 30 amp fuse and it did not blow but it didn't fix the problem. What can I do next?[/quote:597d2c0700]
dont do that, you can fry the wires, take a test light and stick it in the disconnected horn wires have some one push the horn and see if it lights up the horn may be pulling to much amps, if it still blows the 10 fuse its in the wiring to the horn that needs to be addressed
Apr 29, 2008 at 5:21 AM
BUZZSAW
  • 1,198 POSTS
[quote:a5ea7ed827="2CarPro Jack"]https://www.2carpros.com/forum/viewtopic.php?p=248765#248765
Dont do what?? you are basically repeating what I just posted.[/quote:a5ea7ed827]
Jack we musta been answering this at the same time cause when I posted there wasnt an answer to help these people out, Look at the time we posted lmao
Apr 29, 2008 at 8:37 AM
2CARPRO JACK
  • 11,533 POSTS
oops lol my bad
Apr 30, 2008 at 12:18 AM
