1995 Buick Riviera 1995 Buick Riviera Loss of power/acceler
1995 BUICK RIVIERA
65,000 MILES • 6 CYL • FWD • AUTOMATIC
BPYAZEL
I have a 1995 Buick Riviera, 3.8L supercharged, that has suddenly lost power and won't accelerate past about 35 mph. It will only do about 5 mph up hills and frequently stalls. Starts fine though. No engine light has come on, though I did check it and it does work.
I just replaced the fuel filter and the fuel pump. Had the fuel line pressure checked and it is within normal levels. Next, I had the catalytic converter removed from the vehicle, suspecting it was clogged. The car still will not accelerate.
Btw, the following parts were replaced and are new because of problems within the last year, so hopefully it won't be any of them: air temp sensor, coolant temp sensor, alternator, battery, and harmonic balancer.
I'm not a mechanic, but a friend of mine is and is trying to help me, but I think we might have run into a brick wall here.
Anyone have any ideas?
Feb 26, 2009 at 7:33 AM
BPYAZEL
Well, found the problem. The damn harmonic balancer cracked at the key line again and ended up sliding and throwing the timing off. Someone warned me about buying a Dorman harmonic balancer for this car. Guess I'll listen to them next time. 6 months is how long it lasted. The key is damaged again, so now I have to tear down half the engine to get the key replaced again. What a job this is going to be....
Mar 2, 2009 at 10:07 AM
