1990 Buick Riviera wobbly steering column
PADILLAMPP
Steering problem
1990 Buick Riviera 6 cyl Front Wheel Drive Automatic 130xxx miles
how do i tighten a loose teering column
Oct 5, 2009 at 12:26 PM
AJONES156
assuming its tilt. where column tilts are two press in dowel pins. one/both have come loose or popped out entirely. remove panel beloww column. then remove plastic shroud directly behind steering wheel (covers ignition cylinder as well). U should be able to see pivots(dowel pins) or where they should go. these pins can be purchased cheaply at dealer. believe they also make slightly oversized pins to account for wear.
Dec 28, 2009 at 5:57 PM
BENDERMIESTER
did u fix your steering wheal ? im haven same prob mine really loose...
Sep 16, 2010 at 9:21 AM
